Zum Hauptinhalt wechseln
Brentwood TS-292B Browning Dial Circuitboard Replacement
Was du brauchst
  1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: Schritt 1, Bild 1 von 3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: Schritt 1, Bild 2 von 3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: Schritt 1, Bild 3 von 3
    • Remove the five screws indicated using a Philips head screwdriver.
  2. Brentwood TS-292B Browning Dial Circuitboard Replacement: Schritt 2, Bild 1 von 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: Schritt 2, Bild 2 von 2
    • Pull hard on the browning lever until it detaches from the toaster.
    • It will take some force to pull it off.
    • Once the tab is off, lift up on the housing to remove it from the toaster.
  3. Brentwood TS-292B Browning Dial Circuitboard Replacement: Schritt 3, Bild 1 von 1
    • Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
  4. Brentwood TS-292B Browning Dial Circuitboard Replacement: Schritt 4, Bild 1 von 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: Schritt 4, Bild 2 von 2
    • There are four screws on the circuit board for the browning dial.
    • Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
  5. Brentwood TS-292B Browning Dial Circuitboard Replacement: Schritt 5, Bild 1 von 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: Schritt 5, Bild 2 von 2
    • There are two holes on the board where the pin from the browning dial can align.
    • Refer to the images if you are having trouble finding them.
    • Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
    • Replace the entire circuit board if need be.
Abschluss
Elly Ayala
739 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 221
