Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will show how to remove and replace the power wire in a Brentwood TS-292B toaster.
  1. Remove the five 6mm screws on the bottom of the toaster with a Phillips #2 screw driver.
    • Remove the five 6mm screws on the bottom of the toaster with a Phillips #2 screw driver.
  2. To remove the toasting lever, pull the lever away from the toaster.
    • To remove the toasting lever, pull the lever away from the toaster.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Unplug the wire connecting the casing to the circuit board to fully remove the toaster casing.
    • Unplug the wire connecting the casing to the circuit board to fully remove the toaster casing.
  5. Unscrew the wire bracket with a Phillips #2 screw driver.
    • Unscrew the wire bracket with a Phillips #2 screw driver.
  6. Pull back on the black tab that is holding the circuit board in place.
    • Pull back on the black tab that is holding the circuit board in place.
    • While pulling the tab back, lift up on the circuit board.
  7. Desolder the power wire connections on the circuit board.
    • Desolder the power wire connections on the circuit board.
    • Desolder in a well ventilated area.
    • The tip of soldering iron is hot handle with caution.
Abschluss
Elly Ayala
739 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 79
