Zum Hauptinhalt wechseln
Breville BKC600XL On/Off Switch Replacement
Was du brauchst
  1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: Schritt 1, Bild 1 von 3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: Schritt 1, Bild 2 von 3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
    Frag FixBot
    Kommentar hinzufügen
  2. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: Schritt 2, Bild 1 von 2 Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: Schritt 2, Bild 2 von 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
    Frag FixBot
  3. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: Schritt 3, Bild 1 von 2 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: Schritt 3, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
    Frag FixBot
  4. Breville BKC600XL On/Off Switch Replacement, Power Cord: Schritt 4, Bild 1 von 2 Breville BKC600XL On/Off Switch Replacement, Power Cord: Schritt 4, Bild 2 von 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
    Frag FixBot
  5. Breville BKC600XL On/Off Switch Replacement, On/Off Switch: Schritt 5, Bild 1 von 1
    • Carefully pull both the red and blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
    Frag FixBot
  6. Breville BKC600XL On/Off Switch Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch need to be tied back into the wires that lead to the battery. If needed, use electrical tape.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 1-3, Propen Fall 2012 Mitglied von Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Mitglieder
18 Anleitungen geschrieben
3 Kommentare zur Anleitung
Any source for the switch?
Mark Bell - Antwort Teilen
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
Boyd Gilbert - Antwort Teilen
This repair worked like a charm! Boyd Gilberts part number link was perfect....coffee machine is running great once again.
anthonypetric112 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 59
Insgesamt: 4,578
