Zum Hauptinhalt wechseln
Breville BKC600XL Water Valve Replacement
Was du brauchst
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: Schritt 1, Bild 1 von 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: Schritt 1, Bild 2 von 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: Schritt 1, Bild 3 von 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: Schritt 2, Bild 1 von 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: Schritt 3, Bild 1 von 3 Breville BKC600XL Water Valve Replacement, Silver Casing: Schritt 3, Bild 2 von 3 Breville BKC600XL Water Valve Replacement, Silver Casing: Schritt 3, Bild 3 von 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: Schritt 4, Bild 1 von 1
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
Abschluss
Antonio
120 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 1-3, Propen Fall 2012 Mitglied von Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Mitglieder
2 Kommentare
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - Antwort
Hi same question :)
Aiqui2@hotmail.com - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 5,823
