Zum Hauptinhalt wechseln
Breville JE98XL Juice Fountain Plus Lid Replacement
  1. Breville JE98XL Juice Fountain Plus Lid Replacement, Pulp Basket: Schritt 1, Bild 1 von 1
    • Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
  2. Breville JE98XL Juice Fountain Plus Lid Replacement: Schritt 2, Bild 1 von 1
    • Tilt the juicer slightly to the right so the pulp basket is off of your surface.
  3. Breville JE98XL Juice Fountain Plus Lid Replacement: Schritt 3, Bild 1 von 1
    • Pull the pulp basket down and out from under the juicer cover.
  4. Breville JE98XL Juice Fountain Plus Lid Replacement, Lid: Schritt 4, Bild 1 von 2 Breville JE98XL Juice Fountain Plus Lid Replacement, Lid: Schritt 4, Bild 2 von 2
    • Place one hand on either side of the safety locking arm.
    • Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
  5. Breville JE98XL Juice Fountain Plus Lid Replacement: Schritt 5, Bild 1 von 2 Breville JE98XL Juice Fountain Plus Lid Replacement: Schritt 5, Bild 2 von 2
    • Firmly grip both sides of the juicer. Twist clock-wise and lift to remove the lid.
Abschluss
Kurt Wacker
207 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S23-G4, Livingston Spring 2017 Mitglied von Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 233
