Zum Hauptinhalt wechseln
Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement
Was du brauchst
  1. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement, Pulp Basket: Schritt 1, Bild 1 von 1
    • Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
  2. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: Schritt 2, Bild 1 von 1
    • Tilt the juicer slightly to the right so the pulp basket is off of your surface.
  3. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: Schritt 3, Bild 1 von 1
    • Pull the pulp basket down and out from under the juicer cover.
  4. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement, Safety Locking Arm: Schritt 4, Bild 1 von 2 Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement, Safety Locking Arm: Schritt 4, Bild 2 von 2
    • Place one hand on either side of the safety locking arm.
    • Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
  5. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: Schritt 5, Bild 1 von 2 Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: Schritt 5, Bild 2 von 2
    • Locate the two 1 inch Phillips #1 screws on the back of the safety arm.
  6. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: Schritt 6, Bild 1 von 2 Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: Schritt 6, Bild 2 von 2
    • Remove the safety locking arm by gripping both sides and pulling horizontally away from the juicer.
Abschluss
Cal Poly, Team 15-1, Livingston Fall 2016 Mitglied von Cal Poly, Team 15-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G1
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 1,066
