Zum Hauptinhalt wechseln
Briefcase Strap Holder Replacement
Was du brauchst
  1. Briefcase Strap Holder Replacement, Strap Holder: Schritt 1, Bild 1 von 1
    • Cut the whole old strap holder from the bag.
    • If the strap holder breaks in other parts, cut it all out.
  2. Briefcase Strap Holder Replacement: Schritt 2, Bild 1 von 2 Briefcase Strap Holder Replacement: Schritt 2, Bild 2 von 2
    • Draw a longer shape of the strap holder with a pencil on another piece of fabric.
    • Both extensions should be the same length, at least 1/4 to 1/2inch long.
  3. Briefcase Strap Holder Replacement: Schritt 3, Bild 1 von 1
    • Cut the piece of fabric.
  4. Briefcase Strap Holder Replacement: Schritt 4, Bild 1 von 2 Briefcase Strap Holder Replacement: Schritt 4, Bild 2 von 2
    • Add glue in the center of the new piece of fabric.
    • Glue the strap holder on in the center and leave the same length on both sides.
    • You can also use a glue gun.
  5. Briefcase Strap Holder Replacement: Schritt 5, Bild 1 von 2 Briefcase Strap Holder Replacement: Schritt 5, Bild 2 von 2
    • Use a sewing machine to sew the strap holder with the glued piece of fabric in the center.
    • If you have good sewing skills, you can sew on both sides.
  6. Briefcase Strap Holder Replacement: Schritt 6, Bild 1 von 2 Briefcase Strap Holder Replacement: Schritt 6, Bild 2 von 2
    • Place the metal strap holder between the leather strap holder and fold it.
    • Use the sewing machine to sew the tips of the fabric that was glued on the leather strap holder.
    • If your metal strap holder is openable, sew without the metal strap holder.
  7. Briefcase Strap Holder Replacement: Schritt 7, Bild 1 von 2 Briefcase Strap Holder Replacement: Schritt 7, Bild 2 von 2
    • Add more glue between the fabric and the leather strap holder to strengthen it and hold it while it dries.
  8. Briefcase Strap Holder Replacement: Schritt 8, Bild 1 von 1
    • Trim the area where the strap holder is placed.
  9. Briefcase Strap Holder Replacement: Schritt 9, Bild 1 von 3 Briefcase Strap Holder Replacement: Schritt 9, Bild 2 von 3 Briefcase Strap Holder Replacement: Schritt 9, Bild 3 von 3
    • Add glue with a glue gun to the area where the strap holder is placed.
    • Place the strap holder in the strap holder area of the bag and hold it while it dries.
    • It is recommended to sew the strap holder fabric to the area where it will be placed.
Ziellinie
Hao Yi Michelle Lu
169 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-8, Vidal-Chiesa Fall 2024 Mitglied von UC Davis, Team 1-8, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S1G8
2 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 62
Insgesamt: 539
