Einleitung
The pull cord is used to start the lawn mower; it can often become broken or need replacement. Additionally, make sure you have a large table for the replacement and a rag nearby for wiping off any grease and oil. You will need a standard ratcheting socket wrench with a 3/8" and 5/16" driver as well as a Phillips #2 screwdriver.
Was du brauchst
Use a Phillips #2 screwdriver to remove the two 25mm screws on top of the engine cover.
Use your hands to lift the engine cover off, separating it from the rest of the engine.
Slip the pull cord through the engine top cover after separating it.
Use a socket wrench with a 5/16" socket to remove the three 17mm screws that keep the fuel tank attached.
Tilt the fuel tank back at least 45 degrees to get it out of your way.
Use a socket wrench with a 3/8" socket to remove the two 26mm screws at the back of the engine shield.
Use a socket wrench with a 5/16" socket to remove the 17mm screw on the top of the engine shield.
Remove the oil funnel from the rest of the engine. It should pull away easily and come off completely.
Use a socket wrench with a 3/8" socket to remove the two 20mm screws on the front of the engine shield.
Pull the cord back until it is completely unwound from the starter mechanism spool.
Wedge a screwdriver into the gap to hold the spool in place.
Cut the end of the pull cord with scissors or a knife.
Line up the hole on the outside of the engine shield with the hole on the inside, then slip the new pull cord through and tie a knot.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
12 Kommentare
Thanks alot for this guide. I was able to get the pull cord fixed without hassle at all. When I saw my string about to break I knew I was about to blow a bunch of money to have it fixed. Thanks again!
Anyone know how to fix a carb fire
took me right through to the part where the cord is run but not wound and pretensioned ready for start, now what?
Go back to step 8, where it says to pull the cord out and wedge a screwdriver in the spool to hold it under tension. If you have no cord on the spool, you'll have to rotate it to put the spool under tension, then wedge a screwdriver in to hold it, insert the new cord, tie the knot, then remove the screwdriver to release the tension, so the spool will wind the cord up.
