Einleitung
This guide will take you through the process of removing the motherboard of the device in order to get access to components located underneath.
Was du brauchst
Remove three 8mm screws from the left side of the device.
Remove four 8mm screws from the right side of the device.
Apply pressure on the SD card to pop it out of the port.
Remove the card by pulling it out.
Press down on the top cover of the device and slid it towards you until you see a slight gap created.
Lift the top cover off.
Slide the body case back away from the bottom.
Pull up the body case to remove it from the bottom.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
