Zum Hauptinhalt wechseln
Broan-Nutone NU230BL Filter and Light Replacement
Was du brauchst
  1. Broan-Nutone NU230BL Filter and Light Replacement, Filter and Light: Schritt 1, Bild 1 von 1
    • Make sure the fan switch is centered, and the light switch is set to "off" to avoid any injuries.
  2. Broan-Nutone NU230BL Filter and Light Replacement: Schritt 2, Bild 1 von 1
    • Squeeze both ends of the bulb cover to pop it out of the slots.
  3. Broan-Nutone NU230BL Filter and Light Replacement: Schritt 3, Bild 1 von 2 Broan-Nutone NU230BL Filter and Light Replacement: Schritt 3, Bild 2 von 2
    • Make sure the lightbulb is cool before handling to avoid burns.
    • Unscrew and remove the lightbulb by turning it counterclockwise.
  4. Broan-Nutone NU230BL Filter and Light Replacement: Schritt 4, Bild 1 von 3 Broan-Nutone NU230BL Filter and Light Replacement: Schritt 4, Bild 2 von 3 Broan-Nutone NU230BL Filter and Light Replacement: Schritt 4, Bild 3 von 3
    • Twist the latch above the filter clockwise.
    • Slide the filter out by gently pulling it.
  5. Broan-Nutone NU230BL Filter and Light Replacement: Schritt 5, Bild 1 von 3 Broan-Nutone NU230BL Filter and Light Replacement: Schritt 5, Bild 2 von 3 Broan-Nutone NU230BL Filter and Light Replacement: Schritt 5, Bild 3 von 3
    • Insert the new filter.
    • Rotate the retaining latch counterclockwise to secure the filter.
  6. Broan-Nutone NU230BL Filter and Light Replacement: Schritt 6, Bild 1 von 2 Broan-Nutone NU230BL Filter and Light Replacement: Schritt 6, Bild 2 von 2
    • Install the new lightbulb and turn it clockwise.
  7. Broan-Nutone NU230BL Filter and Light Replacement: Schritt 7, Bild 1 von 2 Broan-Nutone NU230BL Filter and Light Replacement: Schritt 7, Bild 2 von 2
    • Reinsert the lightbulb cover by pressing both sides and fitting the cover's tabs into the slots.
Abschluss
Your range hood is good-to-go!
Eine weitere Person hat diese Anleitung absolviert.
Mahdi M
169 Reputation
1 Anleitung geschrieben
York University, Team P-21, O'Regan Winter 2022 Mitglied von York University, Team P-21, O'Regan Winter 2022
YORK-O'REGAN-W22SPG21
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 29
Insgesamt: 804
