Einleitung
Whether you're a beginner or an experienced at sewing it's essential to know how to properly install a needle to ensure smooth and accurate stitching. Here's a step-by-step guide on how to fix a needle on a sewing machine.
Was du brauchst
Locate the screw and turn the screw counterclockwise (left).
Loosen the screw gently and carefully remove the needle.
Take the new needle, place the needle carefully at the base of the opening.
Secure the new needle, locate the screw and turn it clockwise (right) until tightened.
Secure the needle once again. We will start to re-thread the sewing machine.
Place the thread on the lever with the loose piece of thread on the outside.
Take the loose piece of thread and place it through the hood that is present at the top of the sewing machine.
Pull the thread down towards you in the open on the front of your machine.
Hook the thread at the end of the opening.
Take your thread and locate the hole that is in the needle.
Put the thread through the hole.
Make sure that the thread is through the needle. Pull the thread down underneath the presser foot.
You have now finished replacing the needle and rethreading the sewing machine.
In conclusion, fixing a needle on a sewing machine is a fundamental skill for any person using a sewing machine. By following a few simple steps, you can ensure that the needle is securely and correctly positioned, leading to smooth and accurate stitching.
