Einleitung
This guide will be showing you how to remove and replace the thread cutter on a Brother CS6000i sewing machine. The thread cutter is a handy feature that allows the user to safely and easily cut the excess thread from the machine and workpiece. Some symptoms related to a faulty thread cutter are the thread not cutting when attempting to use the cutter (dull blade) or the thread cutter being overly exposed and no longer safe due to a broken blade enclosure.
Was du brauchst
Abschluss
