Einleitung
Whether you manage a busy business or handle a variety of printing activities at home, keeping your printer at peak performance is critical for producing high-quality prints. If you've been experiencing print quality difficulties or received a low toner notice, it's time to replace the old cartridge with a new one. Do not fear, we have created this step-by-step tutorial to help you navigate the toner cartridge replacement process with confidence and precision.
Before we begin, gather the essential supplies, including a replacement toner cartridge for your Brother DCP-L2550DW model. Familiarize yourself with your printer's components to guarantee a smooth procedure; our extensive instructions will walk you through each step. Let's begin!
Was du brauchst
Unplug your printer from the outlet. Identify your printer and the toner cartridge required.
Place the drum unit on a clean flat surface.
Press down on the green button at the bottom left corner of the drum unit to unlock the toner cartridge.
Remove the toner cartridge from the drum unit.
Insert the new toner cartridge into the drum unit by placing it on top of the drum unit and pressing it down, ensuring it is in the locked position.
Insert the drum unit back into the printer by placing it at the edge of the opening and sliding it inside until it locks in place.
Replacement completed. Plug the printer back in the outlet and test it out. You can now use your printer.
Eine weitere Person hat diese Anleitung absolviert.
