Einleitung
This is an easy to follow guide on replacing the ink cartridge in a Brother MFC-7240 Printer. Before starting make sure you have the correct toner cartridge that is compatible with the Brother MFC-7240 Printer. Check the toner package; it should say MFC-7240 as one of the compatible printers.
Was du brauchst
Lift the printer cover which is located at the front of the printer to reveal the toner cartridge compartment.
Put your fingers under the slot underneath the toner cartridge and gently pull it out.
Press down on the small green lever on the bottom left of the drum unit to release the cartridge.
Eine weitere Person hat diese Anleitung absolviert.
