Zum Hauptinhalt wechseln
Brother MFC-490CW Wireless module Replacement
Was du brauchst
  1. Brother MFC-490CW Wireless module Replacement, Remove screws holding the front panel: Schritt 1, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: Schritt 2, Bild 1 von 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: Schritt 2, Bild 2 von 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: Schritt 2, Bild 3 von 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Wireless module Replacement, Remove the screw: Schritt 3, Bild 1 von 1
    • Unscrew the 14.1mm screw located at the left side of the device.
    • Unscrew the 12.1mm screw to the right of the 14.1mm screw.
  4. Brother MFC-490CW Wireless module Replacement: Schritt 4, Bild 1 von 3 Brother MFC-490CW Wireless module Replacement: Schritt 4, Bild 2 von 3 Brother MFC-490CW Wireless module Replacement: Schritt 4, Bild 3 von 3
    • Pry open the left front panel away from the printer
    • Be careful. The panel is attached with a data cable.
  5. Brother MFC-490CW Wireless module Replacement: Schritt 5, Bild 1 von 2 Brother MFC-490CW Wireless module Replacement: Schritt 5, Bild 2 von 2
    • Carefully unplug the connector attached to the device.
  6. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: Schritt 6, Bild 1 von 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: Schritt 6, Bild 2 von 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: Schritt 6, Bild 3 von 3
    • Separate the two clips that hold the module in place.
    • Lift up the module.
Abschluss
To reassemble your wireless module, follow these instructions in reverse order.
Matt
64 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-4, Miles Fall 2014 Mitglied von UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 52
Insgesamt: 1,951
