Zum Hauptinhalt wechseln
Einleitung
The Brother PT-1010 requires 6-AAA batteries. The batteries are organized in two layers one on top of the other. This guide will inform you on proper battery replacement.
  1. Turn device so you are looking down at the top
    • Turn device so you are looking down at the top
  2. Press firmly on arrow indicator and pull panel toward you. Press firmly on arrow indicator and pull panel toward you.
    • Press firmly on arrow indicator and pull panel toward you.
  3. Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
    • Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
    • Make sure the battery compartment is empty and clear of debris.
  4. Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment. Do the same thing to insert the next 2 batteries.
    • Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment.
    • Do the same thing to insert the next 2 batteries.
  5. The next 3 batteries will be inserted on top of the others.
    • The next 3 batteries will be inserted on top of the others.
    • Insert the 4th battery with the flat side (indicated by the - symbol on the battery) facing to the right of the battery compartment.
  6. Repeat step 5 to insert the last 2 batteries.
    • Repeat step 5 to insert the last 2 batteries.
  7. Reinsert back panel.
    • Reinsert back panel.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Haley Sweet
460 Reputation
4 Anleitungen geschrieben
Baylor, Team 4-4, Williams Fall 2014 Mitglied von Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Mitglieder
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 10
Letzten 30 Tage: 51
Insgesamt: 3,315
