Einleitung
The entire motor/gear assembly housing should be removed before starting.
Was du brauchst
First: To separate the top cover from the body, insert a spudger between the two halves.
Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
Carefully pinch the top of the connector.
Pull perpendicular to the device until the wire is disconnected.
Using the metal spudger, swivel the pin so that the print roller lever loosens.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Hi everybody ,does anyone knows were I can by such a lever ?
TBH
Did anyone find a source for this part?
Unfortunately very discontinued. Until someone adds it to thingverse there's not much that can be done.
UN8026001 ROLLER HOLDER ASSY PT100/110
UN8031001 ROLLER HOLDER SPRING PT100
UN8032000 ROLLER RELEASE LEVER PT100/110
I can fix these by using plastic weld to rebuild the edging. I was totally successful.
