Zum Hauptinhalt wechseln
Brother PT-110 Printer Motor Replacement
Was du brauchst
  1. Brother PT-110 Printer Motor Replacement, Batteries: Schritt 1, Bild 1 von 2 Brother PT-110 Printer Motor Replacement, Batteries: Schritt 1, Bild 2 von 2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Printer Motor Replacement: Schritt 2, Bild 1 von 1
    • Remove the batteries.
  3. Brother PT-110 Printer Motor Replacement, Back Plate: Schritt 3, Bild 1 von 2 Brother PT-110 Printer Motor Replacement, Back Plate: Schritt 3, Bild 2 von 2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Printer Motor Replacement: Schritt 4, Bild 1 von 1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Printer Motor Replacement: Schritt 5, Bild 1 von 1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Printer Motor Replacement: Schritt 6, Bild 1 von 1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Printer Motor Replacement: Schritt 7, Bild 1 von 2 Brother PT-110 Printer Motor Replacement: Schritt 7, Bild 2 von 2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Printer Motor Replacement: Schritt 8, Bild 1 von 3 Brother PT-110 Printer Motor Replacement: Schritt 8, Bild 2 von 3 Brother PT-110 Printer Motor Replacement: Schritt 8, Bild 3 von 3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Printer Motor Replacement, Printer Motor: Schritt 9, Bild 1 von 1
    • Remove the motor housing.
  10. Brother PT-110 Printer Motor Replacement: Schritt 10, Bild 1 von 2 Brother PT-110 Printer Motor Replacement: Schritt 10, Bild 2 von 2
    • Unscrew the two 3 mm Phillips #1 screws from the motor housing.
    • Total: 2 x Screws
  11. Brother PT-110 Printer Motor Replacement: Schritt 11, Bild 1 von 1
    • Remove the motor.
Abschluss
IUPUI, Team 1-1, Harley Fall 2016 Mitglied von IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 781
