Einleitung
In this guide, you will see how to replace the tape cassette to your Brother PT-1290.
Turn the device off.
Turn the brother label maker over and press down on the top part (by the face plate) and push on the circle part with ridges.
Gently pull the label maker apart. It will split in half, but be careful with the back piece to prevent any damage.
When inserting the tape cassette it should snap into place. Check to see if the tape is feeding under the tape guides.
Now, that you have inserted the tape, place the batteries back. Make sure they are in the proper direction and place in tightly. Close the label maker, press the power button and is now ready for use.
After installing the tape press the up key to feed the tape then the cutter button to cut the tape off.
