Zum Hauptinhalt wechseln
Brother PT-90 Personal Labeler Disassembly
Was du brauchst
  1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: Schritt 1, Bild 1 von 2 Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: Schritt 1, Bild 2 von 2
    • Start with your device off. The screen should be blank and not displaying anything.
    • Turn the device over so it's resting face down.
    • You should be able to see the model name of the label-maker, as well as a window in which you can view the label cartridge.
  2. Brother PT-90 Personal Labeler Disassembly: Schritt 2, Bild 1 von 3 Brother PT-90 Personal Labeler Disassembly: Schritt 2, Bild 2 von 3 Brother PT-90 Personal Labeler Disassembly: Schritt 2, Bild 3 von 3
    • Using your thumb, press in and then upward on the fastener at the top of the device. The back of the device should come off easily.
    • Remove the 4 batteries located on the left side of the device.
  3. Brother PT-90 Personal Labeler Disassembly: Schritt 3, Bild 1 von 3 Brother PT-90 Personal Labeler Disassembly: Schritt 3, Bild 2 von 3 Brother PT-90 Personal Labeler Disassembly: Schritt 3, Bild 3 von 3
    • To remove the label cartridge from the device, use a plastic opening tool from your iFixit tool kit.
  4. Brother PT-90 Personal Labeler Disassembly: Schritt 4, Bild 1 von 3 Brother PT-90 Personal Labeler Disassembly: Schritt 4, Bild 2 von 3 Brother PT-90 Personal Labeler Disassembly: Schritt 4, Bild 3 von 3
    • Attach the J1 Screwdriver Bit to the extension tool from your tool kit.
    • Remove all of the screws from the back of the device.
  5. Brother PT-90 Personal Labeler Disassembly: Schritt 5, Bild 1 von 2 Brother PT-90 Personal Labeler Disassembly: Schritt 5, Bild 2 von 2
    • Once the screws have been removed, press as shown on the fastener.
    • Carefully open the device.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
University of Maine, Team 2-1, Diaz Fall 2016 Mitglied von University of Maine, Team 2-1, Diaz Fall 2016
UMAINE-DIAZ-F16S2G1
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 28
Insgesamt: 808
