Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Gently pull out the ribbon cable from the circuit board.
    • Gently pull out the ribbon cable from the circuit board.
    • The ribbon cable is very fragile.
  2. Remove two-pin plastic connector from the circuit board.
    • Remove two-pin plastic connector from the circuit board.
    • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
  3. Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver. Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
    • Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
  4. Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
    • Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
  5. Disconnect the LCD ribbon cable from the circuit board.
    • Disconnect the LCD ribbon cable from the circuit board.
Abschluss
Jeston Mitchell
308 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 13-16, Regan Winter 2014 Mitglied von Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 30
