Zum Hauptinhalt wechseln
Brother PT-D200 Keyboard Replacement
Was du brauchst
  1. Brother PT-D200 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-D200 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the six AAA batteries.
  3. Brother PT-D200 Keyboard Replacement, Back of Device: Schritt 3, Bild 1 von 1
    • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
  4. Brother PT-D200 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
  5. Brother PT-D200 Keyboard Replacement, Face Plate: Schritt 5, Bild 1 von 1
    • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
  6. Brother PT-D200 Keyboard Replacement: Schritt 6, Bild 1 von 2 Brother PT-D200 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
  7. Brother PT-D200 Keyboard Replacement, Keyboard: Schritt 7, Bild 1 von 2 Brother PT-D200 Keyboard Replacement, Keyboard: Schritt 7, Bild 2 von 2
    • Peel off the rubber keyboard of the device.
Abschluss
[deleted]
301 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 478
