Einleitung
This guide will walk you through the process of replacing a dead or broken LCD screen on a Brother PT-D200.
Was du brauchst
Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
