Einleitung
Printing documents with the Brother Printer DCP-L2540DW requires the use of toner, but once that toner runs out it is time for it to get replaced. This helpful guide lays out clear and concise steps to assist you on how to replace an empty toner cartridge for your Brother Printer DCP-L2540DW with the correct toner sizes so that you can continue with your printing needs. Before attempting to replace the toner be sure to purchase one of the correct sizes. The TN660 allows for more uses than TN630, hence the reason why it costs more. Toner cartridges can be disposed of in the recycling bin. It is also important to note that contact with the printer transfer roller should be avoided as the toner can rub off onto the surrounding environment and can potentially make the toner cartridge ineffective.
Push down on the lever lock to unlock the cartridge from the drum unit.
Remove the cartridge from the drum unit and recycle it.
Unpack the new toner cartridge from its packaging.
Gently shake the cartridge to evenly distribute the toner throughout the printer transfer roller.
Remove protective cover enclosing the printer transfer roller
Insert the new cartridge in the drum unit.
Clean the corona wire with the slide tab near the front side of the drum unit by sliding it left and right several times.
Return the slide tab back to its original position before continuing.
Insert the drum unit with the new toner cartridge attached at a slight incline back into the printer.
Ein Kommentar
I have done this process and the printer is still telling saying that we need to put in toner?? Can not figure out why?? Any help??
