Zum Hauptinhalt wechseln
Brother Printer HL 3140 CW Paper Jam fix
Was du brauchst
  1. Brother Printer HL 3140 CW Paper Jam fix, take off back cover: Schritt 1, Bild 1 von 2 Brother Printer HL 3140 CW Paper Jam fix, take off back cover: Schritt 1, Bild 2 von 2
    • Stick your printer on a table and get to the back of it. Then remove the white flap from its hinges. you may need to bend the plastic a little for the plastic studs to pop out.
  2. Brother Printer HL 3140 CW Paper Jam fix, remove inside cover: Schritt 2, Bild 1 von 2 Brother Printer HL 3140 CW Paper Jam fix, remove inside cover: Schritt 2, Bild 2 von 2
    • With the white flap off, unscrew the single screw and pry out this black cover.
    • Once out this will allow you to un-clip and remove the paper guide from the printer.( pinch the two green levers)
  3. Brother Printer HL 3140 CW Paper Jam fix, remove photocell shroud: Schritt 3, Bild 1 von 2 Brother Printer HL 3140 CW Paper Jam fix, remove photocell shroud: Schritt 3, Bild 2 von 2
    • You now have access to the black shroud that covers the photocell emitter & receiver. Pry it upwards and off with a small opening tool.
    • Inspect the paperguide: a small black spring loaded lever in the middle should move the "blocking piece" freely up and down.
    • Reassemble in reverse order, ensuring the blocking piece moves freely between the photocell emitter & receiver.
Abschluss
To reassemble your device, follow these instructions in reverse order. This may be the fix you are looking for or perhaps your printer has a different issue. Clearly a slight knock to this plastic shroud meant the photocells were no longer aligned and this printer was unusable...until now.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
14 Kommentare
OMG THANK YOU SO MUCH! I have spent untold hours on the phone with Brother — and finally ran across your post. Worked in 2 minutes. THANKS!
Jason Martin - Antwort
It’s not explicitly clear here - but what you are doing is removing and LEAVING OUT the black U shaped shroud from the device.
brantwalsh - Antwort
OMG thank you... I took it apart and didn't see whatever spring thing he was talking about was, and read your comment and my printer is working again.
Gregory Beaber Jr -
Wow, you nailed it! As soon as I read your observation that the machine always stopped at exactly the same spot - despite there being no paper jam - my mood changed. It worked like a charm. Thanks for sharing the experience with others.
Stuart Clark - Antwort
Thank you! Totally worked. To add to post we removed the shroud and left it off.
jen_phan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 44
Insgesamt: 5,605
