Einleitung
Most sewing machine issues occur because of the needle. Regularly changing out broken or dull needles is an important aspect of maintaining a sewing machine. The needle is responsible for the quality of stitching, but can also affect the how the sewing machine functions. A broken or dull needle not only damages the fabric, but can damage the bobbin case below, and bunch up both the top and bottom threads. Properly inserting a new needle, as well as assessing which needle is required for your project can save you from a variety of sewing machine headaches.
Was du brauchst
Adjust the needle with the handwheel towards you until it is at the highest position, as indicated by the silver thread take-up lever.
Unscrew the bolt that holds the needle in place using either the tool that came with your Brother machine, or a small flat object like a coin.
Select a Brother brand needle, using the needle size that works well with your fabric.
Insert the needle with the flat side of the stem facing the back of the machine.
Screw the bolt in first with your fingers and then with the tool until the needle is tightly secured.
Congratulations! You have successfully replaced your broken needle. Happy sewing!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
