Einleitung
In this step we will be removing the rear casing from the sewing machine. This is necessary to access the inside components of the machine.
Was du brauchst
Place the machine on a solid surface.
Remove the 14mm Phillips #2 screw holding on the face cover.
Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
Lay the machine on its side.
Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
5 weitere Personen haben diese Anleitung absolviert.
