Zum Hauptinhalt wechseln
Brother XR-40 Lightbulb Replacement
Was du brauchst
  1. Brother XR-40 Lightbulb Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Brother XR-40 Lightbulb Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Brother XR-40 Lightbulb Replacement: Schritt 3, Bild 1 von 1
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Brother XR-40 Lightbulb Replacement: Schritt 4, Bild 1 von 1
    • Remove the bottom panel.
  5. Brother XR-40 Lightbulb Replacement: Schritt 5, Bild 1 von 1
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  6. Brother XR-40 Lightbulb Replacement, Lightbulb: Schritt 6, Bild 1 von 1
    • Using scissors, clip the two zip ties securing the lightbulb wire.
  7. Brother XR-40 Lightbulb Replacement: Schritt 7, Bild 1 von 1
    • Place the machine on its side, with access to the bottom.
    • Gently pull out the white wire connecting the bulb to the machine.
  8. Brother XR-40 Lightbulb Replacement: Schritt 8, Bild 1 von 1
    • Move the wire out from under the plastic hook.
  9. Brother XR-40 Lightbulb Replacement: Schritt 9, Bild 1 von 1
    • Using the flathead screwdriver, remove the 5mm Flathead screw holding on the lightbulb bracket.
  10. Brother XR-40 Lightbulb Replacement: Schritt 10, Bild 1 von 1
    • Remove the lightbulb assembly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kevin Bickers
673 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 2-12, Amido Winter 2014 Mitglied von Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 3,051
