Einleitung
Replacing the lightbulb involves opening up the machine. You will need to purchase a sewing machine bulb set, including the wire plug-in, to replace it.
Was du brauchst
Place the machine on a solid surface.
Remove the 14mm Phillips #2 screw holding on the face cover.
Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
Lay the machine on its side.
Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
Place the machine on its side, with access to the bottom.
Gently pull out the white wire connecting the bulb to the machine.
Place the machine upright.
Using the flathead screwdriver, remove the 5mm Flathead screw holding on the lightbulb bracket.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
