Einleitung
In order to switch the stitching styles of your sewing machine, the stitch select knob must be properly functioning. This guide will show the steps for replacement.
Was du brauchst
Place the machine on a solid surface.
Remove the 14mm Phillips #2 screw holding on the face cover.
Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
Lay the machine on its side.
Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
Eine weitere Person hat diese Anleitung absolviert.
