Einleitung
A quick guide to replacing the battery in a Buick key fob
This specifc guide was written for a 2019 Buick Key Fob, but should apply to most Buick Key's with push to start.
The battery is a CR2032
Was du brauchst
Push the chrome button on the back of the key fob to release the inner key
Using an opening tool/pick helps avoid damage, however you can also use the inner key to pry the two shells apart
If using the inner key to pry them apart, just reinsert the tip of the key into fob and gently twist
Slide a tool underneath the old battery to pop it out, the replacement battery goes in face down toward the bottom shell
Eine weitere Person hat diese Anleitung absolviert.
