Zum Hauptinhalt wechseln
Burton 3D Snowboard Binding Replacement
Was du brauchst
  1. Burton 3D Snowboard Binding Replacement, Bindings: Schritt 1, Bild 1 von 1
    • Use a screwdriver to remove all screws from the old snowboard setup by turning them counterclockwise.
    • Repeat this process for the second binding.
    • You will have eight total screws.
  2. Burton 3D Snowboard Binding Replacement: Schritt 2, Bild 1 von 1
    • Wipe your new snowboard using a wet wipe to get rid of any dust/residue.
    • Having dust or residue on the board could result in improper installation.
    • Repeat this on the second binding once done with the first one.
  3. Burton 3D Snowboard Binding Replacement: Schritt 3, Bild 1 von 1
    • Set the binding at your desired stance width.
    • If you're unaware of what your stance angle is, you could use a measuring tape and measure from the base of your foot to your knee. Doing so will give you a rough estimate of what your stance width is.
  4. Burton 3D Snowboard Binding Replacement: Schritt 4, Bild 1 von 1
    • Align the multi-disk plate so only the three screw holes are visible, then secure it in place.
    • If four holes are visible, the plate is misaligned and can cause loose bindings.
    • Repeat this step for the second binding.
  5. Burton 3D Snowboard Binding Replacement: Schritt 5, Bild 1 von 1
    • Adjust the multi-disk angles to your preferred riding stance.
    • Rotating the binding toward the nose creates a positive angle, while rotating it toward the tail creates a negative angle.
    • Set both bindings to ensure consistent comfort and control while riding.
  6. Burton 3D Snowboard Binding Replacement: Schritt 6, Bild 1 von 1
    • Loosely screw in all three screws into the binding once all multi-disk adjustments have been completed.
    • Caution: Try not to use a power drill because the inside of the board is easy to damage as well as the tips. Your hands should do an excellent job!
  7. Burton 3D Snowboard Binding Replacement: Schritt 7, Bild 1 von 1
    • Insert your boot into your binding and see if you either have too much toe or heel drag.
    • If you do, you could move your binding either backwards if you have toe drag or forwards if you have heel drag.
    • When attempting to do this and you are not able to, it means that you did not previously leave your screws loose enough.
  8. Burton 3D Snowboard Binding Replacement: Schritt 8, Bild 1 von 2 Burton 3D Snowboard Binding Replacement: Schritt 8, Bild 2 von 2
    • With the boot still inside the binding, adjust both the toe strap and heel strap so that the top sleeve of the binding sits in the center of the biding.
    • This must be done in order to ensure proper tightening when using the ratchet straps.
    • The heel strap is the strap closer to the base of your foot.
    • The toe strap is the one closest to your toes.
    • Once done repeat on the second binding and boot.
  9. Burton 3D Snowboard Binding Replacement: Schritt 9, Bild 1 von 2 Burton 3D Snowboard Binding Replacement: Schritt 9, Bild 2 von 2
    • This setup uses Nidecker Flow Nexus bindings, which allow you to remove the snowboard boot by pulling down the back strap.
    • For other bindings, loosen the front ratchet straps to remove the boot.
    • Repeat the process for the second binding.
  10. Burton 3D Snowboard Binding Replacement: Schritt 10, Bild 1 von 1
    • With the boots removed, firmly screw in the three binding screws by hand.
    • Check that each binding is secure by gently wiggling it—if it moves, retighten the screws.
    • Avoid using a power drill to prevent damage to the board.
    • Repeat for the second binding.
Abschluss
Once everything is fully secured you are now ready to head out to the mountains and get to shredding!
David Fernandez
181 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 8-10, Grodsky Spring 2025 Mitglied von CSU Los Angeles, Team 8-10, Grodsky Spring 2025
CSULA-GRODSKY-S25S8G10
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 95
