Zum Hauptinhalt wechseln
CASIO CDP-230R Speaker Replacement
Was du brauchst
  1. CASIO CDP-230R Speaker Replacement, Panels: Schritt 1, Bild 1 von 3 CASIO CDP-230R Speaker Replacement, Panels: Schritt 1, Bild 2 von 3 CASIO CDP-230R Speaker Replacement, Panels: Schritt 1, Bild 3 von 3
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
  2. CASIO CDP-230R Speaker Replacement: Schritt 2, Bild 1 von 3 CASIO CDP-230R Speaker Replacement: Schritt 2, Bild 2 von 3 CASIO CDP-230R Speaker Replacement: Schritt 2, Bild 3 von 3
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
  3. CASIO CDP-230R Speaker Replacement: Schritt 3, Bild 1 von 3 CASIO CDP-230R Speaker Replacement: Schritt 3, Bild 2 von 3 CASIO CDP-230R Speaker Replacement: Schritt 3, Bild 3 von 3
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
  4. CASIO CDP-230R Speaker Replacement: Schritt 4, Bild 1 von 3 CASIO CDP-230R Speaker Replacement: Schritt 4, Bild 2 von 3 CASIO CDP-230R Speaker Replacement: Schritt 4, Bild 3 von 3
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
  5. CASIO CDP-230R Speaker Replacement: Schritt 5, Bild 1 von 3 CASIO CDP-230R Speaker Replacement: Schritt 5, Bild 2 von 3 CASIO CDP-230R Speaker Replacement: Schritt 5, Bild 3 von 3
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
  6. CASIO CDP-230R Speaker Replacement: Schritt 6, Bild 1 von 3 CASIO CDP-230R Speaker Replacement: Schritt 6, Bild 2 von 3 CASIO CDP-230R Speaker Replacement: Schritt 6, Bild 3 von 3
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
  7. CASIO CDP-230R Speaker Replacement: Schritt 7, Bild 1 von 3 CASIO CDP-230R Speaker Replacement: Schritt 7, Bild 2 von 3 CASIO CDP-230R Speaker Replacement: Schritt 7, Bild 3 von 3
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
  8. CASIO CDP-230R Speaker Replacement: Schritt 8, Bild 1 von 3 CASIO CDP-230R Speaker Replacement: Schritt 8, Bild 2 von 3 CASIO CDP-230R Speaker Replacement: Schritt 8, Bild 3 von 3
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
  9. CASIO CDP-230R Speaker Replacement, Speaker: Schritt 9, Bild 1 von 1
    • Lay the speaker flat on the table and remove the four black 10mm J head screws with a J1 screwdriver.
    • You may want to use a screwdriver with a bigger handle for a better grip to remove these screws.
  10. CASIO CDP-230R Speaker Replacement: Schritt 10, Bild 1 von 2 CASIO CDP-230R Speaker Replacement: Schritt 10, Bild 2 von 2
    • Grasp the speaker from the center and lift the speaker out of the panel.
  11. CASIO CDP-230R Speaker Replacement: Schritt 11, Bild 1 von 2 CASIO CDP-230R Speaker Replacement: Schritt 11, Bild 2 von 2
    • Follow the cable from the speaker to the button panel.
    • Pull the speaker cable out of the button panel with a slight wiggle.
    • Repeat steps nine through eleven to remove the other speaker.
Abschluss
Cal Poly, Team S4-G2, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
What is the part number for the CDP-230r speaker replacement? I cannot find them online or through Casio. Thanks.
Oli Morgan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 1,548
