Zum Hauptinhalt wechseln
CHI Original Circuit Board Replacement
Was du brauchst
  1. CHI Original Circuit Board Replacement, Hinge Spring: Schritt 1, Bild 1 von 2 CHI Original Circuit Board Replacement, Hinge Spring: Schritt 1, Bild 2 von 2
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Circuit Board Replacement: Schritt 2, Bild 1 von 1
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Circuit Board Replacement: Schritt 3, Bild 1 von 1
    • Remove the hinge pin.
  4. CHI Original Circuit Board Replacement: Schritt 4, Bild 1 von 1
    • Separate the two halves of the CHI Original.
  5. CHI Original Circuit Board Replacement: Schritt 5, Bild 1 von 2 CHI Original Circuit Board Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Circuit Board Replacement, Power Cord: Schritt 6, Bild 1 von 2 CHI Original Circuit Board Replacement, Power Cord: Schritt 6, Bild 2 von 2
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Circuit Board Replacement: Schritt 7, Bild 1 von 1
    • Gently pull upwards on the connection point and disconnect the power cord.
  8. CHI Original Circuit Board Replacement, Circuit Board: Schritt 8, Bild 1 von 3 CHI Original Circuit Board Replacement, Circuit Board: Schritt 8, Bild 2 von 3 CHI Original Circuit Board Replacement, Circuit Board: Schritt 8, Bild 3 von 3
    • Remove the (2) .27" Phillips head screws on each half of the CHI Original.
  9. CHI Original Circuit Board Replacement: Schritt 9, Bild 1 von 3 CHI Original Circuit Board Replacement: Schritt 9, Bild 2 von 3 CHI Original Circuit Board Replacement: Schritt 9, Bild 3 von 3
    • Remove the covers on both halves.
  10. CHI Original Circuit Board Replacement: Schritt 10, Bild 1 von 1
    • Remove (2) .15" Phillips screws from the circuit board.
  11. CHI Original Circuit Board Replacement: Schritt 11, Bild 1 von 2 CHI Original Circuit Board Replacement: Schritt 11, Bild 2 von 2
    • Desolder all points of contact between the circuit board and wires on the ceramic heating elements.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Eric Knigga
215 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G2, Freund Fall 2017 Mitglied von IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 47
Insgesamt: 3,034
