Was du brauchst
Remove Bed leveling knobs
Lift bed and set to the back left side of the printer
Remove with M5X30 SHCS one at a time
Replace with M5X30 BHCS
Slide Y carriage off from the front of the machine
Remove from packaging
Note, do not touch the rail directly with your hands.
Wipe down rail with a lint free cloth
Add grease to the grease port on each side of the rail
Pre-insert Spring loaded and use an Allen wrench or screwdriver to help align
M3 Spring loaded T-nut
Use the circled Rail mounting positions
16x M3x8 SHCS
Picture with MGN guide on rail
Remove all Vslot wheels and bolts
Install endstop Trigger at this location
M5x35 SHCS
3x Stock Vslot wheel spacers
M5 Nylon Ring Lock Nut
Belt mounting holes goes on the right side of the priter
Left side screws
2x M4x8 FHCS
M4x10 BHCS - M4 washer - M4 Large OD washer
Tightened the left side screws first
Remove the stock endstop bracket screw
Replace endstop bracket mount screw with:
M3x10 SHCS, M3 Washer and M3 Sliding tnut
Adjust the Endstop position by sliding the endstop back until the nozzle tip lines up with the front edge of the bed when the endstop triggers.
3 weitere Personen haben diese Anleitung absolviert.
