Zum Hauptinhalt wechseln
CR10S Pro V1 MOSFET Upgrade
  1. CR10S Pro V1  MOSFET Upgrade, MOSFET Wiring and installation: Schritt 1, Bild 1 von 3 CR10S Pro V1  MOSFET Upgrade, MOSFET Wiring and installation: Schritt 1, Bild 2 von 3 CR10S Pro V1  MOSFET Upgrade, MOSFET Wiring and installation: Schritt 1, Bild 3 von 3
    • The used mounting holes are boxed in green
    • The red cable from the bed goes the Vout terminal boxed in red on the picture.
    • The black cable from the bed is moved from the -V screw terminal of the Power supply unit(PSU) to the +V screw terminal on the PSU
    • The red cable used to connect between the PSU +V and the SSR will now go to the screw terminal boxed in orange
    • New black cable will connect between the -V on the PSU and the V- on the MOSFET box in Black.
    • New jst pigtail connector cable will connect to the connector on the MOSFET boxed in blue and to the Control Board Bed positive and negative screw terminal for the bed heater
  2. CR10S Pro V1  MOSFET Upgrade, Bed heater Signal connection: Schritt 2, Bild 1 von 1
    • The MOSFET Signal connection Connects to the Bed Heater port Blue
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
AJ Pereira
2.744 Reputation
16 Anleitungen geschrieben
Tiny Machines 3D Mitglied von Tiny Machines 3D
Community
5 Mitglieder
41 Anleitungen geschrieben
2 Kommentare zur Anleitung
Hi AJ, thx a lot for your help! Klaus from TOP CLASSIC CARS LLC
Klaus Hackbarth - Antwort Teilen
Hi!
With a delay of 3 years... Thanks for the instructions! Would this be valid for the Creality CR 10s PRO v2? I got this model in 2019... it remained stuck on my mind that it was advertised back then as a v2, that's why i wrote it like that. But now I'm not sure as I found this component as a standard in cr10s pro v2 and mine had a SSR module for the heated bed. Well... the SSR module has reached it's time I guess and broke. I compared the mainboards ( mine vs the one in the picture) and I'm a bit confused as I cannot distinguish the marks on the big black square chip and also I have no idea if it matters anyway.
I hope someone can help me, as I don't want to give up on this printer.
Thanks!
Dragos
Dragos - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 48
Insgesamt: 3,591
