Zum Hauptinhalt wechseln
CRKD NEO S CK24NS Button Replacement
Was du brauchst
  1. CRKD NEO S CK24NS Button Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Turn the CRKD NEO S CK24NS upside down with the front-facing buttons facing downward.
    Frag FixBot
    Kommentar hinzufügen
  2. CRKD NEO S CK24NS Button Replacement: Schritt 2, Bild 1 von 3 CRKD NEO S CK24NS Button Replacement: Schritt 2, Bild 2 von 3 CRKD NEO S CK24NS Button Replacement: Schritt 2, Bild 3 von 3
    • Use a 1.5 mm Hex screwdriver to remove the eight 1.5 mm Hex screws from the back of the controller.
    • Carefully lift off the back panel and set it aside.
    Frag FixBot
  3. CRKD NEO S CK24NS Button Replacement: Schritt 3, Bild 1 von 3 CRKD NEO S CK24NS Button Replacement: Schritt 3, Bild 2 von 3 CRKD NEO S CK24NS Button Replacement: Schritt 3, Bild 3 von 3
    • Remove the four 2.5 mm screws holding the motherboard in place using a Phillips #0 screwdriver.
    • Take out the white plastic pieces connected to the motherboard with tweezers.
    • Gently lift the motherboard and set it aside.
    • If the small red plastic piece next to the audio jack falls out, don’t worry. You can pop it back into place during reassembly.
    Frag FixBot
  4. CRKD NEO S CK24NS Button Replacement, Button: Schritt 4, Bild 1 von 2 CRKD NEO S CK24NS Button Replacement, Button: Schritt 4, Bild 2 von 2
    • Depending on the button(s) you want to replace, lift them out with a pair of tweezers and put the new buttons in.
    • Make sure the controller is facedown because the buttons will fall out.
    Frag FixBot
Abschluss
Utah Tech University, Team 1-1, Crenshaw Fall 2024 Mitglied von Utah Tech University, Team 1-1, Crenshaw Fall 2024
UTAHTECH-CRENSHAW-F24S1G1
3 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
Where can one find replacement buttons?
Carlos - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 46
Insgesamt: 543
