Einleitung
This guide will show you how to replace the motherboard in the CRKD NEO S CK24NS controller.
Be sure to power off and disconnect the controller from any power source before beginning this procedure.
Was du brauchst
Turn the CRKD NEO S CK24NS upside down with the front-facing buttons facing downward.
Use a 1.5 mm Hex screwdriver to remove the eight 1.5 mm Hex screws from the back of the controller.
Carefully lift off the back panel and set it aside.
Remove the four 2.5 mm screws holding the motherboard in place using a Phillips #0 screwdriver.
Take out the white plastic pieces connected to the motherboard with tweezers.
Gently lift the motherboard and set it aside.
