Zum Hauptinhalt wechseln
Cabin air filter replacement for a SEAT Cordoba II (2002-2009)
Was du brauchst
  1. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: Schritt 1, Bild 1 von 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: Schritt 1, Bild 2 von 2
    • The cabin air filter is located in the passenger side footwell
  2. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: Schritt 2, Bild 1 von 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: Schritt 2, Bild 2 von 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: Schritt 2, Bild 3 von 3
    • Remove the cover by loosening the four screws that hold it in place, keeping track of where they go to replace them in the some holes.
    • Once that the screws are removed, the cover will come down.
  3. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: Schritt 3, Bild 1 von 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: Schritt 3, Bild 2 von 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: Schritt 3, Bild 3 von 3
    • Now with more room to remove it, slide the two plastic tabs together.
    • When the two plastic tabs are in the middle pull the filter cover down.
  4. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: Schritt 4, Bild 1 von 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: Schritt 4, Bild 2 von 2
    • Remove the filter.
    • Once you remove the filter make sure to notice the direction of the air-flow arrows so that you install the new one in the same direction.
  5. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Re-assembly: Schritt 5, Bild 1 von 1
    • To install the new filter follow the previous steps in reverse. If the filter and the plastic cover don't install fully, it is possible that it is installed backwards.
    • When re-installing the cover re-insert the tab and push upwards. Then reinstall the screws.
Ziellinie
6 weitere Personen haben diese Anleitung absolviert.
es en
100%
WhoDat? hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Jonatan M
620 Reputation
2 Anleitungen geschrieben
Ein Kommentar
me agremio para conocer formas de reparar yo mismo y economisar el presupuesto mensual
oscar ibarra - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 74
Letzte 30 Tage: 230
Insgesamt: 9,364
