Zum Hauptinhalt wechseln
Cabinet Door Butt Hinge Replacement
Was du brauchst
    1. Cabinet Door Butt Hinge Replacement, Cabinet Door Butt Hinge: Schritt 1, Bild 1 von 1
      • Determine where the cabinet needs repair: on the top or bottom hinge.
      Frag FixBot
      Kommentar hinzufügen
    2. Cabinet Door Butt Hinge Replacement: Schritt 2, Bild 1 von 1
      • Measure the hinge to make sure you have the correct size of your butt hinge.
      • Measure the distance between the screws and the height and width of the hinge to get the correct hinge.
      Frag FixBot
    3. Cabinet Door Butt Hinge Replacement: Schritt 3, Bild 1 von 1
      • Remove the screws from the door with a Phillips #00 screwdriver and remove the hinge.
      • Keep the screws nearby; you will need them later.
      Frag FixBot
    4. Cabinet Door Butt Hinge Replacement: Schritt 4, Bild 1 von 1
      • Align the cabinet door to stand straight with any surrounding cabinets.
      Frag FixBot
    5. Cabinet Door Butt Hinge Replacement: Schritt 5, Bild 1 von 1
      • Place the new hinge where the previous one was. Align the holes together.
      Frag FixBot
    6. Cabinet Door Butt Hinge Replacement: Schritt 6, Bild 1 von 1
      • Tighten the hinge into place using the same screws with your Phillips #00 screwdriver.
      Frag FixBot
Abschluss
If the door closes parallel to any surrounding cabinets, your fix is complete!
Laura Carew
133 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 77
Insgesamt: 1,832
