Zum Hauptinhalt wechseln
Calculator is Stuck While Graphing
  1. Calculator is Stuck While Graphing, Calculator is Stuck While Graphing: Schritt 1, Bild 1 von 1
    • To cancel the graphing process, press the "ON" button.
  2. Calculator is Stuck While Graphing: Schritt 2, Bild 1 von 3 Calculator is Stuck While Graphing: Schritt 2, Bild 2 von 3 Calculator is Stuck While Graphing: Schritt 2, Bild 3 von 3
    • Go to "Zoom." Navigate to and highlight "ZoomFit" then press "Enter." Doing so will automatically set your graphing window to the most appropriate dimensions.
  3. Calculator is Stuck While Graphing: Schritt 3, Bild 1 von 1
    • If you are graphing complex equations, multiple equations, or a combination of the two, it may take anywhere from 1 minute to 5 minutes to graph.
    • The bar on the top right corner indicates the calculator is graphing.
  4. Calculator is Stuck While Graphing: Schritt 4, Bild 1 von 2 Calculator is Stuck While Graphing: Schritt 4, Bild 2 von 2
    • If you feel that your graph is taking too long, you can change the step resolution to a bigger number. To do so, press "Window" and change "Xres" to a value between 1 and 8. A bigger Xres value will graph more quickly.
Abschluss
It is always a good idea to make sure your graph will display a good window.
John Baek
31 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 7-52, Forte Fall 2012 Mitglied von Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Mitglieder
14 Anleitungen geschrieben
0 Guide Comments
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 9
Insgesamt: 2,015
