Einleitung
Questa guida illustrerà come sostituire le pile in un sistema Game Boy.
Was du brauchst
Usa un'unghia (o una piccola moneta) per spingere verso il basso il fermo dello sportello della batteria e rimuovi lo sportello della batteria.
Utilizza un'unghia per estrarre ogni batteria dal polo positivo (+) per rimuoverla.
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
25 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Simone hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
4 Kommentare
This was a very helpful guide. I had no idea how to replace the batteries for my GameBoy, but thanks to this amazing and helpful guide, I was able to do so. The only issue that I have with this guide is that it did not explain how to properly dispose the used batteries. I ended up soaking them in gasoline and lighting them on fire because the colors look super pretty. Don’t breath the smoke though! I’m pretty sure the smoke is toxic?
I have struggled with this for 20 years. Thank you.
Awesome! I finally know how!
