Einleitung
This guide describes the steps necessary to replace the motherboard of the system. This board contains the circuitry for the amplification, power, and output.
Was du brauchst
Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
It may require some wiggling, but it should slip out of the hole and then off of the cord.
Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
Remove the green grounding wire from the mounting screw.
With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
Unscrew ground wire from main case.
De solder 4 wires coming from transformer.
The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
