Zum Hauptinhalt wechseln
Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
Was du brauchst
  1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: Schritt 1, Bild 1 von 2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: Schritt 1, Bild 2 von 2
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
  2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: Schritt 2, Bild 1 von 1
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
  3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 3, Bild 1 von 1
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
  4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 4, Bild 1 von 1
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
  5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
  6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 6, Bild 1 von 1
    • Separate the battery from the bottom plate and set the bottom plate aside.
  7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 7, Bild 1 von 1
    • With some force, push the motherboard straight in toward the center of the device.
  8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 8, Bild 1 von 1
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
  9. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 9, Bild 1 von 1
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
  10. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Unplug the wires that connect the speakers to the motherboard.
  11. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 11, Bild 1 von 1
    • Unplug the thin white cable connected to the buttons.
  12. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 12, Bild 1 von 2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: Schritt 12, Bild 2 von 2
    • Desolder the wires that connect the LED to the motherboard.
Abschluss
USF Tampa, Team 1-1, Nance Spring 2016 Mitglied von USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 1,884
