Einleitung
Use this guide to replace the damaged or broken speaker cover of your Cambridge SoundWorks OontZ Angle Plus Speaker. The detailed steps will guide you if you are planning to customize your speaker and change the color of the cover. This is a relatively quick and easy replacement process.
Was du brauchst
Starting from the screw covers, remove the front and back casing of the device.
Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
Once the plates are separated, slowly pull the bottom plate away from the top plate.
Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
