Zum Hauptinhalt wechseln
Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement
Was du brauchst
  1. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Rubber Casing: Schritt 1, Bild 1 von 1
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: Schritt 2, Bild 1 von 1
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: Schritt 3, Bild 1 von 1
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: Schritt 4, Bild 1 von 1
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Speaker Grill: Schritt 5, Bild 1 von 1
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: Schritt 6, Bild 1 von 1
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: Schritt 7, Bild 1 von 1
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: Schritt 8, Bild 1 von 1
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: Schritt 9, Bild 1 von 1
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: Schritt 10, Bild 1 von 2 Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: Schritt 10, Bild 2 von 2
    • Finally, bend the speaker cover upward and it will slide out.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 1-1, Nance Spring 2016 Mitglied von USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 971
