Was du brauchst
Starting from the screw covers, remove the front and back casing of the device.
Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
Once the plates are separated, slowly pull the bottom plate away from the top plate.
Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
With some force, push the motherboard straight in toward the center of the device.
