Zum Hauptinhalt wechseln
Campbell Hausfeld FP204800 On/Off Switch Replacement
Was du brauchst
  1. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: Schritt 1, Bild 1 von 3 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: Schritt 1, Bild 2 von 3 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: Schritt 1, Bild 3 von 3
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: Schritt 2, Bild 1 von 2 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: Schritt 2, Bild 2 von 2
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: Schritt 3, Bild 1 von 1
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the On/Off Switch Wiring: Schritt 4, Bild 1 von 1
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: Schritt 5, Bild 1 von 2 Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: Schritt 5, Bild 2 von 2
    • Twist the On/Off switch from the underside of the shroud.
    • Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
    • When the switch has reached the correct position, you will feel it "click" into place.
  6. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the on/off switch: Schritt 6, Bild 1 von 1
    • Push the on/off switch from the underside of the shroud until it comes loose.
    • If the switch is not in the correct position highlighted in the previous step, it will not be easily removed and could damage the shroud.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Caleb Davies
528 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-29, Maness Fall 2014 Mitglied von Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 1,480
