Zum Hauptinhalt wechseln
Campbell Hausfeld FP204800 Pressure Gauge Replacement
Was du brauchst
  1. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: Schritt 1, Bild 1 von 3 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: Schritt 1, Bild 2 von 3 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: Schritt 1, Bild 3 von 3
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: Schritt 2, Bild 1 von 2 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: Schritt 2, Bild 2 von 2
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: Schritt 3, Bild 1 von 1
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the On/Off Switch Wiring: Schritt 4, Bild 1 von 1
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: Schritt 5, Bild 1 von 2 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: Schritt 5, Bild 2 von 2
    • Using a Smart Wrench, remove the old/broken pressure gauge or gauges.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric
409 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 14-29, Maness Fall 2014 Mitglied von Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 983
