Einleitung
To replace the pressure gauges, you must first remove the shroud of the compressor. Even though the pressure gauges seem easy to remove, there is still some disassembly required to complete the replacement.
Was du brauchst
Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
Gently pull the wire attached from the pressure switch to the on/off switch.
It should come off the pressure switch with ease.
Gently pull the wire connected from the on/off switch to the motor of the compressor.
Using a Smart Wrench, remove the old/broken pressure gauge or gauges.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
